Well, the body bushings really don't require much to change them. You basically unbolt one side all the way, then jack up the body under the floor with a long board between the jack and floor to support it. It only needs come up about 2-3 inches at most to change them. The body will pivot on the opposite side's bolts and stay in place. This all works great in theory, but can ruin your day if your car is rusty or a bolt breaks off. I did my car in 1997, when it was still fairly new and it had never seen salt. I also greased the rear frame rails with axle grease after sanding and painting what I could get to in order to protect it from rust. My car was showing signs of rust at the body bushing at the back of the wheel well at that time and I wanted to be sure it didn't get much worse. I only greased the back of the frame where the tires typically kick a lot of dirt up and blast the paint off. It is covered by the body in this spot, so only I know it was done. The grease does hold dirt, but it helps form a rust proof crust around the metal. It is basically British Rustproofing...lol..., so named because of the tendency of those cars to leak oil badly and rust badly in any spot not slicked down by the leaks.
