I finally got my S60 (Dana) "Ready to Bolt In" rear end. It is equipped with the ends to install my Camaro Rear disk backing plates. Well, the Camaro backing plate hole is too small and doesn't let the axle go into the housing at all. I've been grinding for the last couple of days making the hole bigger. Got one side ground enough for the axle bearing to go thru it and allow the axle retaining plate to bolt up to the housing. Once I did that, it fits perfectly.
I had to space out lower shock mount with a "T" shaped bracket purchased online on the 10 bolt cause the caliper sticks in too much. The S60 trailing arm bracket is shaped different from the 10 bolt , so I'll have to make my own bracket once the S60 is bolted in place. The bracket has multiple holes to adjust the lower control arm angle.
Otherwise, it's a bolt in with some modifications on small stuff. It is a great looking piece of pig iron, very well made!
Pics to follow tomorrow.
