Just make yourself one of these.
I fill the m/c and clamp this on with a C-clamp.
Put 20 psi max in,I just hit it with the tire chuck for like 1/2 a second.
It WILL get ugly if you just stick the tire chuck on blast it with 120psi.
Start in the back ,bleed the brakes.
Release the pressure, top off the m/c and repeat on the front,works everytime.
If you are just bleeding,after only losing a small amount of fluid,you can just leave it on and do front and back (this assumes there is the "cut" in the well diver).
On old style m/cs I have to switch it around anyway.
