Hi everyone. I'm based in Brisbane, Australia and have an 81 El Camino. I've recent completed an LS1 swap and she's running like a dream.
After the engine swap I noticed the brake booster made a hissing noise when depressing the brake pedal. The brakes worked fine and the engine idle changed slightly. It was the original booster single diaphragm so I got my mechanic to replace it with a new dual diaphragm booster from Rockauto, unfortunately the noise was still there with the new booster. The mechanic seemed to think it might just be a "thing" with these boosters.
I've since looked to upgrade the brakes to the blazer spindle/caliper setup and had investigated the b-body booster and master cylinder upgrade to support extra braking. This combined with the noisey/vacuum booster in the car I purchased again a new b-body booster and went to another mechanic for a second opinion and to complete the swap. I've just got the car back and this third booster is making the hissing noise when depressing the pedal. This mechanic thinks the booster is faulty and to try swap it.
Firstly, is it likely I'm having a bad run of boosters or is this normal noise/behaviour? This seems unlikely
Secondly, is there a trick or common issue with my setup that may be causing this to occur? Anything I should look at?
Finally, could the LS swap cause this? Is the vacuum too strong or have any impact?
Thanks,
Christian
Thanks,
Christian
