Hi guys , I recently did a full brake restoration on my 1986 v8 Montecarlo, after the job was finished I have next to nothing braking power!… also I noticed that there’s bubbling inside the MC when brake is pressed in the rear chamber that holds the fluid for the front! At first I thought it was a defective MC so I changed it and it did the same thing .. I changed out the master cylinder 4 times already
There’s no break fluid leaks at all anywhere In the car ….
I bled the crap out of the system !
The pedal goes to the floor when car is on
It feels like there’s no pressure whatsoever going to the brakes ..
I replaced the following
•Brake booster
•master cylinder (4 times because the past 3 were defective)
•rotors
•calipers
•brake pads
• wheel cylinders
•drum brakes and all the springs
•rear hard brake line
•Russell braided line for the rear
•Russell braided lines for the front
I properly bench bled the MC
And also properly bled all 4 wheels . I’m stumped you guys I could really use some help
Thanks in advance
-Santana
•Brake booster
•rotors
•calipers
•brake pads
• wheel cylinders
Thanks in advance
-Santana
