After getting the right coil compressor & the front suspension back together, I'm now running into an issue with standard replacement pads fitting. Fells like a newbie with these simple issues. I'm using stock spindles, calibers, & slotted rotors. The pads are from Autozone (MKD154). The pads don't look like the last set that was used n '03 for the last brake job. The pads have a stud for the wear indicators that catches the spindle when the wear indicator is down, but fits with a little hammer help with the indicator is up, the the rotor won't spin. I still need to check the rotor thickness to compare to stock. After all the A/G bodies I have owned & helped work on, never have I had this issue. Has anyone else run into this problem or just check rotor thickness.
