Two threads, a ton of info and aggravation but the problem has been figured out and FIXED !!!!!
The other day I called AC Delcos tech line to find out the difference between two different year boosters. At that point I replaced everything but that so I figured the heck with it. Whats another $75 right ?
The number I have was for the brake section but only masters, calipers and wheel cylinders. The tech asked me what was going on. I told him everything that happened from the start. His opinion ? Air in the line someplace. When he heard the lines were clamped and the pedal was hard that was it.
So yesterday I cleaned up the area and today I started working on it again.
Long story short, I kept looking for a leaky fitting or line. As soon as I hit the air bleeder a ton of air mixed fluid would come out of both calipers. Not the wheel cylinders though ! It was only the fronts.
Then I remembered the leaking fittings I fixed on the wagon. They wouldnt leak just sitting there. They also didnt show anything when the suction bleeder was working. The only way I knew there was an issue is when someone stepped on the pedal and put pressure on the system. Not suction. Pressure only.
So my buddy came over today and while he stepped on the pedal and held it down I inspected every fitting. I had to use an inspection mirror to see it but the line from the master on the top of the proportioning valve was seeping in the middle of the fitting. It took a few minutes to develop enough to start a drip. With suction only it never dripped but the air got sucked in through the same fitting. Unbelievable !!! All this time for a simple fitting. I hate this crap. lol
