snowmangaggift said:
I have a weird brake problem. When the engine is off, i have a nice firm pedal with very little travel. As soon as i turn the engine on, the pedal sinks and i have no brakes. Ive replaced master cylinder and checked many times for leaks and there are none. Anyone have any ideas?
I had some similar issues with my ride recently......
http://www.gbodyforum.com/viewtopic.php?f=19&t=37113
Just curious...did you bench bleed the master cylinder? This has to be done or you will introduce lots of air into the system. Also, you may have a bad brake booster or the vacuum line to the booster may be cracked/leaking. Why did you replace the master cylinder? If it was leaking, it may have ruined the booster. If you did bench bleed the M/C, I would gravity bleed the system starting at the right rear and working around to the left front, one wheel at a time. You will need a least a quart of new fluid to do this and dont let the M/C get too low or you will have to start all over again....You definately have air in the system...not likey that the booster is bad...but check out the vacuum line going to it.
