I read alot of posts and threads here about people who want to change and/or upgrade the braking systems on their G bodies.
I'll start out by saying that I've owned a number of these cars over the past 25 years or so, and I understand what people are talking about when they say that the original braking system on these cars can be kind of marginal at times, especially if you need to stop in a hurry.
Where I start to get curious is when people want to change the entire braking system to 4 wheel discs, or larger disc brake systems. I understand that larger brakes are more effective, and that disc brakes resist fading due to heat better than drum brakes, and that those people who use their cars for events like autocrossing, need good brakes.
I've read alot of posts and threads though, where people describe problems that arise when they do brake upgrades. Things like, "my 15" stock rims don't clear the new brakes", or "I've had to relocate my lower rear shock mount to provide clearance for the rear disc brake calipers", or "I had to go with an adjustable proportioning valve to get the correct brake bias from front to rear with my new brake setup", or "I can't get my 4 wheel disc brake setup to bleed properly", or other similiar concerns.
Has anyone ever done any kind of comparison test to try to determine exactly what upgrades yield the best improvements in braking performance, in terms of dollars spent versus overall improvement in braking performance?
I know that the 2wd Blazer front brake upgrade is the hot ticket for alot of people right now, and it offers the option of going to the larger Corvette style brakes later on, if desired, but what about rear brake upgrades? Alot of people want to remove the stock drum type rear brakes, and upgrade to discs, but is it really worth it, or are some people just going for the wow factor of seeing rear disc brakes on their car?. I know that the stock rear drum brakes are prone to a number of problems (they're kind of small for the size of the car, the backing plates ave a tendency to rot out, and the wheel cylinders are just held in with a clip, so they can twist and fail, etc.). If the stock type rear drum brakes are in good condition, and properly maintained, they will work well on a car that is just street driven, and even these stock rear brakes can be upgraded a bit (S10 rear wheel cylinders with larger bore pistons, and installing 4 secondary brake shoes). Has anyone ever tried to upgrade the rear drum brakes to a larger drum size? I know that some of the earlier mid 1970s GM A body cars were equipped with 11" X 2" rear brakes, and some of the GM wagons had even larger brakes. Does anyone know of anyone who has done this type of upgrade, as opposed to converting to rear disc brakes?
Sorry for the long-winded post, but after reading many threads about brake upgrades, I'm curious about how effective these upgrades are, and whether or not it was money well spent, and if there are other alternatives, that might yield the same results, with less headaches. Thanks for looking. 😀
