Brakes
Sevnxchmp313
6
Need some help please. 86 Monte ss rear disc conversion.can’t get rear to bleed. Put in new lines a proportion value. Just a little bit of a dribble out of the bleeder. Bad master??? What do you guys think. Thanks in advance!
fly_25
Oct 20, 2020
60
Is the brake light on? You could have caused the prop valve to lock the rear lines if you did not use the tool to keep the valve open when bleeding.
malibudave
180
Houston, TX
1. Do you have fluid coming out of the master cylinder outlet for the rear brakes?
2. It also may be your prop valve "low pressure switch" not being centered and blocking off the rear fluid pressure to your rear calipers.
Similar threads
Similar threads
G-Body Performance Upgrades
