Break in th350?? Oil
Myles
Jun 17, 2011
80
17
8
Hey guys,
So my 81malibu is ready for cam break in tomorrow morning, after almost a year working on it part part time!
(Yes, Monday when everyone's at work)
How much oil / when to add oil to my th350? The entire car is a fresh build.
Th350 fresh with rebestus clutches and upgraded sprag. Stage 2 transgo kit. Builder claims good for 450hp repeated wippings.
8" custom built stall 42-4500. I could barely add any oil during install without loosing it all, it's pretty tiny. Medium sized transmission cooler up front.
We will be 1 guy on timing gun and throttle and 1 guy checking everything else as everythings be changed.
What's a good starting point, a few quarts?
Thanks guys
Myles
First get a friend to help you - too much going on. With an 8in converter, start out with at least 6 quarts. I assume it is a flat tappet to be breaking it in so have good oil w/zinc. Static time the car so you get a quick start and get the RPMS up. While your friend keeps the rpms around 3000 check the timing - 34 to 36 @ 3000 w/o vac. It's all eyes and ears during break-in - watch temp and oil pr. Once done top off all your fluids, add the center valve springs if you have a big cam and your done.
Reactions: DRIVEN
The break in went well! Thanks for all your help.
No leaks, nothing. I think I love solid cams now, lol. And with those 215cc heads, feels like theres no redline haaha
Just have to change the thermostate,
Might try a 160. Its maybe only 375hp with a big 4core and electric pump.
