Today i installed my bucket seat's and the inner mounts. On the driver side the seat sits kinda close to the door & the HINGE COVER TRIM rubs against the door panel. the passenger side is fine tho. any suggestions.....
Did u install the factory spacers/washers between the seat and the seat tracks as the factory did ? If you've already done this, put one or two thin washer along with the factory spacers so it will clear.the82elco said:Today i installed my bucket seat's and the inner mounts. On the driver side the seat sits kinda close to the door & the HINGE COVER TRIM rubs against the door panel. the passenger side is fine tho. any suggestions.....
Evan's 85 said:Did u install the factory spacers/washers between the seat and the seat tracks as the factory did ? If you've already done this, put one or two thin washer along with the factory spacers so it will clear.the82elco said:Today i installed my bucket seat's and the inner mounts. On the driver side the seat sits kinda close to the door & the HINGE COVER TRIM rubs against the door panel. the passenger side is fine tho. any suggestions.....
Thats the problem thenthe82elco said:Evan's 85 said:Did u install the factory spacers/washers between the seat and the seat tracks as the factory did ? If you've already done this, put one or two thin washer along with the factory spacers so it will clear.the82elco said:Today i installed my bucket seat's and the inner mounts. On the driver side the seat sits kinda close to the door & the HINGE COVER TRIM rubs against the door panel. the passenger side is fine tho. any suggestions.....
no i left the spacers out.
