so i'm once again toying with this idea of building up a buick V6 for mild street/daily driving use and i have some questions.
my goal would be 200-250 HP (250 would be ideal). it would be a daily driver so good vacuum is needed.
i have 4 cams to choose from comp cams, http://www.compperformancegroupstores.c ... ode=69-CAM
i'm thinking the 260H would be a good choice.
hedman headers has ceramic coated headers for the buick V6 as well and i'll probably go with those and get rid of the exhaust manifolds. i guess i'll go dual exhaust with it, what would be a good size? i'm guessing a 2" since it is a V6 and it's only a mild build up.
i have a 4.1 intake and it will allow me to use a Qjet so i know it will fit under the hood and i even have the air cleaner for it. however im wondering about the EGR, can i just block it off/leave it non functional or do i need to/should use it? a non CCC qjet shouldnt be too hard to come by and neither should a non CCC distributor.
can i get away with using the stock fuel pump? (i'm guessing yes) but if not does anyone make an aftermarket fuel pump for these things? could i get one for a buick 350 if they make one for it?
feel free to add anything i havent already mentioned. i can get a 3.8 easily and cheaply any time any where and i can get a 4.1 from the junkyard if i look hard enough. i'm betting the 252 would be the better option because of the larger bore. can the 3.8 be bored out to a 4.1?
