350 wouldnt be bad... there is a 1972 Cutlass Convertible on Craigslist that they're parting out it has a 350 in it which I might pick up if it has #5 or #6 heads or maybe just for the block and build it from ground up if im lucky to find those heads. But at the same time a LT1 swap for me was quoted $1500, Engine and everything INSTALLED. that includes engine, transmission, pcm, radiator, cut drive shaft, fuel tank and lines, ac working.
Its a hard choice lol
LT1= Fuel Efficiency, cold AC, strong motor, cold start ups, might pass emissions very clean. 15MPG?
350 #6 heads= Strong, little maintnence, no Wires, cheaper, 10 MPG?
Choices :?:
Hmmm im not to sure right now my shifter is stock and it doesnt hit but it comes very close maybe half an inch from touching the screen but im pretty sure there is different stereo kits that could position your indash lower or higher then where its
Vs
Mine is in the center of the kit
Choices :?:
Vs
