Still leaking water, this time through the hood release cable hole. I will deal with that tomorrow. For today, I scienced out the wiring for the use of a driver's side 88 Cutlass Ciera 3 motor seat track used on the passenger's side seat. Basically, you have three motors: one for back and forth, one front tilt and one rear tilt. The plugs in the motors are interchangeable. To use a driver's side switch and wiring harness, you need to interchange the two tilt motor plugs, and then switch the wires in each plug so that they are reversed. Each plug has 2 wires in it and switching them simply switches the direction everything moves in. This can be done by popping open the connector, then using a tiny jewler's screw driver to release the pins in the bottom of each terminal. You can see them with it opened up. Just switch sides, and presto! They work in reverse! Now all you need are a 10 gauge power wire and ground wire run to the driver's side seat. Sadly, I only have one of the two harnesses I need to run both seats, and I am debating going to pull the second tomorrow. It will probably cost me $30 for the wiring, switch, and gas to get there and I don't think I should spend it.
I also put my Oldsmobile Intrigue multi function mirror in today and it works. It gives me the "C" error code, which means it needs to be driven slowly in a circle until it orients itself. This is normal and it will go away once it is done. As for the wiring, here it is for anyone who wants to do this conversion: Orange mirror wire is constant positive. I used the orange dome light wire for this. Gray is switched negative. I used the white dome light wire for this (remember: GM uses a constant hot and a switched negative for the dome light on our cars). Black-ground. I installed a ring connector and drilled a small hole under the headliner trim piece. Brown- Hot in run. I ran a wire down to it and put a spade connector on it. It is plugged in to the connector next to the A/C fuse with the 10 ga orange with black tracer wire running off it. I believe this is the power seat connector. The green wire I did not run. It is supposed to run to the backup lights in the Intrigue (actually, the transmission selector switch), but it may be a 5 volt data line and not a 12 volt. So, running it may cause the thing to burn out. Remember that about modern cars with multiplex wiring.
Finally, in the nothing goes easy department: The bracket the mirror attaches with is loose on the mirror stand, and so the mirror will not attach securely. I now have to epoxy it and hope that holds and does not get in the way of the installation.
