Hey guys, wanted to see if anyone has had a similar problem to this so I can get it fixed quick.
I was driving the Camino and a bunch of gray smoke came out of the dash from the steering column and it smelled terrible. It went away after 3 seconds. I pulled over and turned off the engine to see if it was alright, and it looked fine to me. I start the car again and notice my battery is not charging (voltmeter dropped to like 11-12 volts, usually at 14-15). I checked every fuse, and everything still works. Any ideas what could have fried? I'm thinking some kind of wires. I'll have to check the alternator with a multimeter tomorrow to make sure it's still good (maybe it fried? The little bolt that holds the wire on the back of it looked like it might be burnt, but I assumed it was jus regular grime), but it's less than 2 years old so it should be fine. I'll post that here when I do it.
Just wanted to see if anyone had ever had a problem like this with their G body. It's an 86 with a 305 by the way. Thanks
