Sand any area a bushing is going to contact smooth.
Don't use the stuff that pack with the bushings, they don't give you enough anyway.
Do take the bushings all the way apart, I mean out of thier metal cases, and lube the hell out of them with Synthetic Brake grease and slide them back in thier case/shell.
Lube inside the bushing and slide the pin in.
Next, I almost fill the pin/bolt hole with grease.
Take the grease brush and lube the outside of the bushing as well as the area you sanded.
You guessed it, lube the bolt and slide it in until there is enough sticking out the other side to thread on the nut.
Hold the nut with a wrench and tighten the bolt in, this pulls the grease in and then seals it inside when the bolt gets tight.
Torque them down tight, then back off a turn.
I then drop the car on 4 ramps, cycle the suspension by riding the bumper.
Now you can do final torque on the bolts.
I have done tons of cars this way with not one complaint of a squeak from my customers.
I did a gear swap on one customers car after 2 years.
I pulled the bolts out of the LCA arms, pushed them down and they swung under the car, no binding here.
