Hi guys.
Can i renove the transmission from a c5 transaxle setup and bolt to the LS engine?
I've been searching hard, and the t56 manual can if you modify the transmission using GTO parts it seems. Not really straight foreward, but definitely doable.
I havent been able to verify if the autonatic transmission can be used though. My guess is that you would have to bolt on a "normal" engine mount transmission bellhousing to the transaxle transmission to mate it to the engine, also using a flexplate and converter. How about for the tail shaft then?
Im asking because i can get my hands on a c5 donor car that is wrecked but with the driveline intact.
Anyone know anything about it?
It is surprisingly hard to find info on using a c5 vette as a donor car for an ls swap!
