I'm looking for some Caballero reference material and I'm not having much luck.
I purchased a 1980 Caballero last month and have been doing some work on it here and there. Through some VIN research I found that it was originally a v-6 car. I do believe it is a factory manual shift car but it would have come with a 3-speed behind that v6.
Since I knew the 350 had been swapped in at some point I did some research on the qjet serial number and the intake/block casting numbers and it appears someone swapped in a 1980 L82 vette engine.
While swapping in some moog 5660 springs and rebuilding the LCA's with new bushings and ball joints I noticed that it has the heavy front sway bar and a rear sway bar. They measure to be the same as my old '84 cutlass which was an F41 option car.
Digging around in the glove box I found a "Caballero Laredo" dash emblem. According to what I can find the "Laredo" is akin to the elco SS package which explains the factory rally pack guage cluster.
So what i'm hunting for and what I'm hoping someone on here may be able to help me with is an options list for a Caballero Laredo. It will help me decide what direction to go with the pickup. Right now it is white with Chevy red/orange above the body line w/ white racing stripes over a cowl hood.
