I'm in the process of doing this exact thing right now, here is my take on it.
Also, many friends and I work the Silver State Classic every year, the requirements there are very different than what's required for drag racing.
- Don't waste the money on a mild steel cage, if you ever outgrow it (and trust me, eventually you will) it's junk and has to be cut out. Spend the few extra bucks now for a 4130 C/M cage, that you can add onto as your car gets faster. A 10 second car and a 6 second car use the same exact 10 point cage as a foundation. Plus you can run a smaller diameter tube (1-5/8 .083 wall) and save a sh*t load of weight)
- S&W makes a kit that goes through the dash, they also can run the rear bars through the package tray so you can have passengers in the back seat, they are called "pro street" rear bars. I have both for my car.
- As Streetbu mentioned above, if you are going to street drive this thing - know what you're getting yourself into.
- Children can never safely ride in the car again, in any seat.
- The back seats are basically out because you need a harness bar that will be in front of the rear passengers face.
- A helmet and/or containment device is a must at all times. Roll bar padding is a joke, it does nothing.
