from looking at you picture, it appears to be blowing out in an area that has an attaching bolt. the olds timing cover is sheet metal, with 4 water pump bolts going through it into the block and it has 4 smaller bolts that thread into the cover. so there are 8 bolts in total holding and sealing the water pump to the engine.
are all the bolts being used and is he able to tighten them fully? particularly the two bottom bolts that thread into the cover?
as stated above, verify integrity of the cover surface and it flatness.
joe
joe
