Hello all I need some help choosing a a cam. My current set up is 350 stock bore I believe .30 over at the most, it has camel humps (186's), 650cfm performance QJ, trans is 200r4, and running 3.73 gears. It currently has a small cam meant to pass smog but I want to wake it up. It is Basically a mild 350....
I want to stick to flat tappet hydralic, with the stock spring/rocker ratio because I dont think its worth investing more money into the camel humps and I also want to run the stock stall converter but wouldnt mind upgrading the converter if necessary to get more out of it cheaply. Oh and this is in an El Camino that will be 90% street, 10%strip and I want it to make some good power
Any suggestions on duration and lift ranges i should be searching for? anyone running a similar combo?
thanks
thanks
