Could be. White smoke usually means coolant. What did the plugs look like when u took them out. If they r too clean, then possibly blown head gasket.
Just remember with the block tester you must make sure that coolant does not mix with the chemical.Otherwise you will not get a accurate reading and that chemical will not be useful anymore85t5mcss said:U can also borrow a block tester. It uses a Purple fluid and draws air into a tube from the radiator. If it turns Yellow, then it "smells" combustion and u have a blown head gasket or cracked head.
