On a small block chevy roller camshaft, how much would 1.6:1 rockers change the duration? Cam duration is 230/236, advertised 282/288. I am lead to believe it is small, but I want to know how much. Is there any type of formula I can use?
pontiacgp said:bill... the higher rocker ratios was started by circle track guys who had to run a certain cam and they wanted more..the 1.6 rockers are still used by guys who cheat....
your right about the operation and since the rocker is a higher ratio when the cam starts to lift the rocker your getting more movement on the valve. It opens sooner and higher and closes later..
