Can anyone take a pic of where this connects?
marcar1993
702
209
New Jersey
Ok so reading these posts jogged my memory. I tucked a bunch of wiring in the drivers fenderwell. I unrolled it all and there was my connector. Blower motor works on high now. (I did replace the relay too, fixed that issue too!)
Tried hooking up the factory ac harness to the low pressure switch and the compressor and still nothing. (I've been running it on a separate wired key on switched relay circuit)
I remember needing to ground a few pins or jumper something to get the factory ac harness to work without the computer. Anyone know exactly what I need so my compressor will come on via the hvac controls and not via a separate circuit?
Thanks so much for the help so far!
marcar1993
702
209
New Jersey
pagrunt
8,469
13,847
Elderton, Pa
I just looked at what I have. One wire coming aff the alternator that splits into 3. One goes to the bulkhead connector, one goes to the AC and the last goes to the starter and that one has the fusible link. Im assuming thats fine since I copied the original harness.
On the OE harness the one fusible link just protects the lights & has no splices. The other protects everything else that gets the main power.
383_StealthRam
176
383
Looking at this diagram I just need to ground the black wire from the c497 plug to do what the ecm is no longer doing then my factory harness will work.
Does this sound correct?
The HVAC dash control should send 12v to the Compressor control relay, and the relay is enabled by finding a ground path through the pressure cycling switch which will send power to the AC Clutch coil.
Simple test is to check for +12v on that green (or light green) wire in that connector when you turn on the AC from the dash. If you don't have power there, backtrack to the dash control head, and it's power feed from the fuse panel. If you do have 12v at the green wire underhood, you need to make sure the pressure switch is working (closed) and providing that ground to turn it on. Of course if the system has no refrigerant in it, that would have to be addressed before troubleshooting the electrical controls imho.
As far as the brown wire goes that used to be grounded by the ECM, here's more info that might help you out... credit to 69hurstolds
Good luck!
