That's why I said use the original tracks if possible. It's easier to adapt the seat to the tracks than adapting the tracks to the floor. If I read your post correctly, you now have a bench seat in the car. It makes the change a little more difficult. Maybe you can find used, worn out G body seats and mount the Cadillac seats to the frames. If you can go this route, grab the mounts from the G body floor because the mounts are different heights to make the seat level. Back in the 80's, I put 68 Camaro seats in my Buick and being young and dumb, I just used pieces of pipe and washers to make the seats level, which they were not. They were very uncomfortable because they were crooked. Also, make sure the mounts are very secure, preferably welded to the floor. You don't want the seat to break loose in an accident!The Deville seats are buckets. They have two tracks per seat. Your bench only has the outboard tracks. You are missing the brackets welded to the floorwell that the inboard tracks bolt onto. So yeah, this is not much different than the situation that you would encounter with any buckets, including the "correct" G-body buckets. However, the spacing between inboard and outboard tracks can be different, for example, in 3rd Gen F-bodies the spacing is narrower. You can get the brackets to weld in, but they are shaped to fit the floorwell shape exactly where G-body track spacing expects them. If the track spacing is different, or you just don't want to weld the brackets in, some kind of adaptation will be required.
