Canaderp Strikes Again
Generally it seems like we're simply moving to regulations that are more inline with what's already in the US, or possibly CARB, which I understand is the strictest in the US.
Oh yes, because California has a great reputation for not being laughably overregulated.
Again, no longer a fan of the guy in the video.
You said that already 🙄 Your opinion of him doesn't change the law that got passed.
The headline is WD-40 being banned.
Yes. That's why we're here. Having this discussion. WD-40 is one product. Maybe not even a good example. Do you guys get PB Blaster up there? Because the SDS for that states <50% VOC. So apparently that won't work for your shiny new bill.
No acetone listed in the chemical composition section. I even checked a few others and don't see acetone is a main ingredient in any of their Brakleen products.
Have you ever actually used Brakleen? Do you know what VOCs are? Brakleen, acetone or not, is straight VOCs in a can. If it wasn't, it wouldn't evaporate, and it wouldn't be brakleen.
It absolutely blows my mind that anyone could be so ignorant that they would attempt to justify this kind of overregulation. I literally cannot believe this is a discussion.
I go through way too much brake and carb cleaner.
I always have some on hand, but have recently converted over to this stuff for cleaning things.
It blows the doors off of Brakleen and carb cleaner, so it's probably illegal now up there too.
And just one more for you, this comes directly from the US EPA website in the form of a PDF, listing the VOC cap on every product you could think of. Penetrants in the US are regulated to 50% VOC content. Let there be no confusion that Canada is simply just aligning their regulations with the US standards as  that is not the case.
Aligning with California, maybe. California is its own world.
Link:
Chapter 3745-112 Volatile Organic Compound Limits in Consumer Products https://www.epa.gov/sites/default/files/2018-07/documents/chapter_3745-112.pdf
The can he plopped on the table was CRC Red. The choice of color on the label is one way the MFGR identifies the product as being high in CFC's or chloro-fluoro-carbons. This is the version of the product that, if used and then heat applied to the fixture, assembly, components, or structure, has the high probability of "cracking" or reacting to the heat by releasing Chlorine Gas. Which, of course, is toxie to the point of causing death. Even mild or passing exposure to Chlorine gas is enough to damage your lungs and other organs, permanently.
As for WD40, so called because it took the inventor 39 initial tries before he got it right the 40th time, it's not the first can of chemical persuasion that I reach for when in need.
The whole restriction and elimination of VOC's has little to do with the environment, that is just the big lie being marketed by the spin doctors. All this falls into the same category as the elimination of hair spray and model car glue. Done purely and simply to close the door to a source of intoxication that certain demographic elements turn to for escapism purposes. Just another example of punishing the innocent for the excesses of the few.
Just my personal opinon here.
I was only pointing out some rather misleading information in the video you posted.
You seem to be taking that personally and assuming my stance on the topic.
I've said my piece.
Yes, we get PB Blaster, just bought a can. Ordering my case of Brakleen this week. It will be interesting what changes exactly and when.
