Remember to check what you can before pulling parts off. With luck you could find the problem with everything together then know what needs to come off.
Yes... Very good advice. Thanks a lot for your insights. 😎
Might be the actual light bulb not being compatible. Try switching the right side bulb to the left .
Hello and thanks for your reply. And believe it or not I tried that last week with no change. ( I've tried everything I do believe ) It stayed stuck on also when blinker was engaged. Appreciate your reply my friend.
Ok, it might be the turn signal switch inside the steering column sometimes they break or contacts go bad.
Sounds like you have the wrong flasher and a burned out front bulb
Hello... No it's the same flasher that has been there all along. Plus the right side is working just fine on the same flasher. Front bulb is fine as it has already been inspected and is good.. But thanks for your replies my friend.
Four ways use a different flasher.
Remove the hasard flasher (upper flasher) and see if anything changes.
