SSmooth84 You really need to answer this question^^^. If the computer is controlling the timing then you're setting the timing wrong.It sounds like you have two issues. First is where did you get the distributor and did you get the distributor with the vacuum advance unit or are you still using the one hooked to the ECU?
305 H.O. Timing Mark... '84 MCSS
I'm seeing a lot of different answers about where the harmonic balancer groove is supposed to sit on the timing mark tab... My emissions decal says "6° BTDC @500 RPM"... I live in Tulsa, OK, elavation here is 722', low altitude Currently, I'm set at 8° BTDC... I can't even get the engine to...
gbodyforum.com
