Bonnewagon said:With motor off, remove air cleaner, plug vacuum nipple. Start motor, check what rpm fast idle is, watch as choke butterfly slowly opens. When fully open, tapping throttle should drop fast idle down to curb idle. That is what SHOULD happen. The grey wire that goes to the round black housing on the side of the carb gets 12 volts when the ignition is ON. It heats up a coil inside and that opens the choke butterfly. If it is not getting 12 volts, or intermittently, choke stays closed, and idle stays too fast.
On a stock 86 307 it would have a hot air choke, not electric.
