Good Day!
I have a 78 Malibu that is set-up for road racing. During high G, but slow corners, the car will die. It is an automatic with a 350 chevy engine. The carb is an edelbrock. The car currently has power steering.
It seems like it is a steering related issue.
I have adjusted the floats to specs and even tried moving higher and lower than specs and have the same problem. I have raised and lowered the fuel pressure from 13 psi to 2.5 psi.
The idle has been raised to 1200 rpm.
I believe it is the steering set-up because if you turn the wheel while sitting still, it will lower the idle by about 4-500 rpm. I think the loads the steering system sees while in a high G corner are higher than sitting still and turning the wheel.
If anybody has any suggestions, I would appreciate it!
Does anybody know what the difference in ratio is between a power box and a manual box?
