Does anyone know why a carb (2bbl rochestor) would make a chattering noise once the ignition is switched on? Its not the starter the car starts fine. The noise continues even when the engine is running. not a valve either. Happens when power is turned on BEFORE the car is started. I know its electrical but why does it do that. Btw its a replacement and a hose was forgotten. The small one that goes from the right side to the lower part of the carb. I'm going to tell the guy when I go to payoff the job. I'll get some pix as some as I can get a cam to use. :x
