Okay, I know that the rule of thumb is that a 4 hole carb spacer will typically boost low to mid-range torque and an open spacer will boost upper end HP.
Now, will the same hold true for a vehicle with a 4bbl EFI throttle body since there is no fuel being introduced before the spacer?
I'm just wondering if a 4 hole spacer would help increase my intake port velocity considering I have a large dominator flange single plane intake and a 1600cfm throttle body to give it a bit more part throttle response.
