:arrow: it seems the carb doesn't open all the way when hard on the accelerator. anybody might know whats preventing this.i have a demon carb on it.
Alright well I'm guessing that you have the wrong type of bracket on the carb. I took some pictures of my set up mabey that will clear things up. Or at least it will help me figure out what is wrong. The vacuum thing is easy. If you have a vacuum secondary there will be a diaphragm on the right side (pass. side) of the carb. If not there will just be a spring. Also you can tell by opening the linkage by hand if only the primaries (front 2 barrels) open then its vacuum. Mechanical is more for racing, you can set it up so all 4 barrels open at the same time.carlitothemac said:ah you got me on the mechanical secondary stuff it a road demon jr725cfm. but is the throttle cable sappose to be straight cause its not.its down (the cable)and the wire has to travel up to the linkage then pull it back. yeah i know this crap sounds stupid but its not pulling it all the way open.
No problem. I got a bracket and ran the return spring off of the front of the intake manifold. I was having problems with the linkage hanging up. The spring/throttle cable/TV cable all in the same place made it a mess.chevy94ss said:sorry to hijack, hey chevyman, where do you have your return spring hooked up?
hijack over
