cat delete
GP4U2NV
194
-1
Cincinnati
www.sidefx.org
84 regal with motor swap. I belive that the car has a OEM xhaust. I want to delete the cat. This car is titled as collector so it is limited use.
I was looking for a bolt in test pipe.
My exhaust cat is flaged on both ends 4 bolt style. I see all over the net the ones that bolt in and then dont go to the rest of the exhaust. Does someone make a true bolt in test pipe?
Do a search on ebay every once in awhile a company will have the four bolt cat test tube up for sale, they are around 60-70 dollars.You can get a exhaust shop to weld one in after cut out the cat if you are really in good with them as it is against the law! lol
