I have just completed my elimination of the Computer Controlled Carb and Intake on my 3.8L 229C.I. V6 in a 1981 El Camino.
The parts I used were the following:
Edelbrock 2111 aluminum intake--says will fit 1985 and up but actually fits 229 V6 just fine.
Holley 1850S 600 CFM 4 Barrel carb with Vacuum secondaries and a manual choke--64cc Main Jets and 70cc Secondary jets--before going and saying this carb is way too big for this motor (which on a stock motor probably would be). I have a 252H Comp Cam upgrade along with Flat top pistons for a higher compression ratio and ported and polished heads and the aluminum dual plane intake. The only adjustment I may need to do is up the Main Jets to 66's instead of the 64's.
Since mine was a 1981 with a vacuum advance distributor I was able to reuse this part and I did not have to purchase a different one.
I have completely unplugged and removed my computer from the El Camino. It has not effected anything else in the car, no check engine lights or dash lights came on and the car started, ran and drives just fine.
