My Champion 3 core fit fine and was just passable with a 403, 195 to 210 with a 160 thermostat. The 2 core with 1" tubes is similar in price and will out cool the 3 core.
Definitely nothing special with my car. It will probably end up being a .030-over 307 Olds. I've heard the 403 is similar to the 400 SBC in terms of cooling (?).
It'll be at least a few months. The 2-row is considerably cheaper. If anything I think the original might not be sufficient for the transmission on really hot days. But, if the 2-row cools better, it will take care of the engine and transmission.
I believe another member here used a 2-row for his 1984 Regal.
Here is mine in my Regal, there were no mods to make it fit but the inlet and outlet were larger than my stock 307 hoses so I had to go with a larger hose on each.
I have Intrepid fans for when I do the engine swap and will install those at that time.
What is the knob/port below the overflow hose on the passenger side tank?
Looks like the upper hose you used is for a mid-late 70's Oldsmobile. Have one coming. Not a problem, though I am leary of using mixed and matched pieces that aren't for the car.
