Champion radiators in a G-Body
kustomkyle
646
47
Wanting to use a Champion Radiator to replace the original (now green) radiator. Engine soon to be rebuilt.
Are the Champion radiators a good overall fit for G-body's? I'm thinking my original radiator is a 3-row, but perhaps a 2-row Champion wold cool better?
How do Champion radiators fit in the factory core supports? No problems/modification with the top plate/bushings/etc.?
565bbchevy
9,614
12,683
Michigan
Here is mine in my Regal, there were no mods to make it fit but the inlet and outlet were larger than my stock 307 hoses so I had to go with a larger hose on each.
I have Intrepid fans for when I do the engine swap and will install those at that time.
kustomkyle
646
47
This is the exact application. It's too bad stock hoses won't work.
565bbchevy
9,614
12,683
Michigan
I think both were a 1/4" too small, the factory outlets are actually downsized from a typical application and for me my plan was new hoses anyways.
565bbchevy
9,614
12,683
Michigan
For Olds 307 here are the part numbers I used which are both made by Dayco, upper hose 70548 and lower hose 70936.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
melloelky
4,162
9,569
mass
my griffin needed a larger lower hose too,the oe was to small. I'm running Gates 22542 fits like a glove looks stock.
kustomkyle
646
47
These should be the hoses I have in the parts collection. Thanks.
Was undecided about whether to go with a 2-row or 3-row. Should be good either way.
Oct 14, 2008
8,826
7,779
Melville,Saskatchewan
My Champion 3 core fit fine and was just passable with a 403, 195 to 210 with a 160 thermostat. The 2 core with 1" tubes is similar in price and will out cool the 3 core.
