I changed my fuel pump on my 350 rocket. now I am not getting any fuel to the carburetor at all. I am going to take it off and do it again. Can anybody tell me what I am doing wrong. Can somebody lead me in the right direction?
tc1959 said:I think the pump arm has to go under the plump drive Eccentric. It's very easy to get it over it , and you can bend the fuel pump arm . :shock:
Thanks I thought it was somthing like that. It's been a long weekdan2286 said:tc1959 said:I think the pump arm has to go under the plump drive Eccentric. It's very easy to get it over it , and you can bend the fuel pump arm . :shock:
On an Olds, you have to go over the fuel pump drive.
Try priming the carb by putting gas down the vent tube.
MWA said:The pumps. On a chevy and a olds are positioned differently. Does the rod on the olds slide in between the grooves on th pump how does it exactly go? How would I put the pump on? Where should I look for this rod to be at because I did not see it the first time?
