I almost did it with a inline 6 Mustang and then I got cancer and the car had to go.
Now I have my 1982 Regal with a 1975 Chevy 350 4 bolt main. I am in the planning stages of a turbo setup. I have most of the basics figured out, fuel pump, bypass regulator, blow off valve, boost controller, pretty much all the basics I have worked out.
There are 2 things that got me scratching my head, Should I go with one big turbo from both banks or should I do 2 small turbo's one for each side?
Second question, when it comes to the ignition timing I am LOST. I don't understand what I need to do. I hear about changing the curve, welding the distributor and all different other things. Anyone have any insight on this?
I plan on doing a inexpensive build and I am not going crazy on parts. Everything will mostly be junkyard parts except for the fuel pump, regulator, blow off valves and whatever else can't be found at the junk yard. I will probably make sure I got the right pistons in my engine before I even attempt it. If I don't then I will just put a 150 shot of NOS on my engine and see what happens Maby have to rebuild the engine :wink:
