clutch pedal problemss
the problem you will come across, which is a problem most people come across with a g-body is this.
the fork for a g-body has a certain bend to it so that it clears the tunnel right. i haven't seen a g-body specific fork that is right in the aftermarket yet, which is why i chose to go full hydraulic. you can recreate the bend in the fork to make it work, but you have to heat up the fork to bend it yourself to make it work.
