as of this post i have yet to get my car back after new suspension installed but that part is done here's some things you need to know. i stuck with stamped steel control arms front & rear cuz didnt want to be bothered with having to grease poly bushings & other potential nightmares that come with tubulars. besides i don't have a ton of HP nor is it ever going to see a track (parts used i'll post below). the biggest issue i had and was prepared for was what this guy dealt with. teaser it looks like he used reinforcement plates in the front but didn't say anything bout them. he didn't weld them in nor did mine get welded in against what others here recommended, my mechanic chose not to and said was glad he didn't i forgot reason but said its not an issue. i trust his judgement on that.
the plates. aldan seems to be only coilover mfg that sells them and separately from their kits. their's are expensive and look weak so i went with these.
southsidemachineperformance.com
coilover kit
rear control arms
front spring insulators
2" drop spindles
front upper control arms
front lower control arms i used allstar bare stampings, i tried to fill them in with delco parts and it failed with the bushings. if had to do it over find generic 1s already done, it was a time delaying mess. here's what used otherwise.
other parts used were BMR products
www.bmrsuspension.com
SSM COILOVER REINFORCEMENT PLATES
Coil-Over MountsSold in sets of 2. These plates built and designed by SSM offer the perfect landing for your coil-overs. The new muscle car coilover conversions offered by the spring companies use the lower shock t bar mount to support the entire weight of your car on a spot that was not...
![southsidemachineperformance.com](https://cdn-0.gbodyforum.com/proxy.php?image=https%3A%2F%2Fimg1.wsimg.com%2Fisteam%2Fip%2F81312f07-644c-4ef3-a27d-2aa5524b196d%2Flogo%2Fd07d8a40-02bc-4c2d-a1a8-0649ceaaa021.png%2F%3A%2Frs%3Dw%3A57%2Ch%3A57%2Cm&hash=464a6aca4497bcc038bd8eddd5cc7838&return_error=1)
coilover kit
rear control arms
2" drop spindles
![www.bmrsuspension.com](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fwww.bmrsuspension.com%2Fbmr_logo.jpg&hash=b0a5aa30e5be4e82dc9f61368281002d&return_error=1)
Free Shipping on all BMR Suspension packages!
Leader in High Performance Suspension and Chassis Products For American Muscle Vehicles.
