compression ratio & pump gas...
bill said:
FE3X CLONE said:
bill said:
Just curious...what does a compression test tell you about the CR? Is the CR identifiable with a compression tester?
No. There is no direct correlation.
TY!
The biggest issue with trying to correlate the cranking psi to a static compression ratio is that depending on what camshaft is used can throw the results.
You could have an engine with 9.5:1 compression with 180psi cranking psi as mentioned above and another with 11:1 compression that also has 180psi because it has a big cam that bleeds off more pressure.
