sorry meant to say smoke coming out the dipstick or oil filler. ill correct the postERIC87442 said:i dont have oil coming out the dipstic or the cap just poots out smoke, but i get oil up in my air cleaner
use the sea foam. put it in before u change ur oil and put at least 20 miles on the car. them change the oil and use some thicker oil. 10w40. i like using 20w50. and see if the blow by clears up and check ur compression again. see if it comes up some and ur smoking filler cap stops. if u have access to a leak down test i would do that to when u check ur compression after sea foam and a fresh oil change.ERIC87442 said:im hoping i just got some sticking rings and i can free some crap up with seafoam or that gm uper intake cleaner
