Thinking the same... A good wrap of tape would or could seal. Won't know until you get engine to operating temp.
But if you look at the threads... They appear to be straight cut and above the threads it is cut for about a 1/8th or 3/16th o-ring. Under the nut is the mating surface and if you inspect the boss, you should see it is machined flush as well. The o-ring pinches in there to seal any imperfection of the mounting.
Can you wrap it good or goop it up with paste? Probably. Will it be ok? Probably. It's only a 15 psi system.
Also that is aluminum going in to machined iron manifold? Don't over do it. Make sure not to cross thread and wrench it down snug. Both mating surfaces should be in contact, then 1/8 to 1/4 turn only. Should be no leaks if done right. Over torque it and you start stripping threads and now will predispose yourself to leaks.
