Hello all, I have in my 85 Buick Regal a 355 4 bolt main sbc. I put on vortec heads along with an edelbrock intake for vortec heads and an eldelbrock 1406 for a carb. I have a comp cam 268h in it and no it is not a hydraulic cam, it's a flat tappet.
Everything was going semi well with my build until I started experimenting with my rockers and push rods. I installed these:
http://www.ebay.com/itm/SBC-Stainle...ash=item58c28063d5:g:FbMAAOSwqu9VJaIp&vxp=mtr
I have a really bad tick and I am pretty sure the cause of it is because of incorrect push rod length. I read all over various forums that it is recommended that the 1.6 rockers are put on the intake side and the 1.5 is put on the exhaust which is exactly what I did. I was hoping by chance someone could shed light on something that I missed that can be causing this unbearable tick. I didn't install any push rod guide plates by the way and I was searching all over various forums for an answer to this. I was just hoping if someone had an answer to that push rods I am supposed to be using without me having to use a pushrod length tester.
I tried a ton of methods on adjusting the rocker arms too by the way, I tried the by the book way and followed Youtube videos on it step by step and also had my father in law do it by ear so I really do not think it comes down to adjustment either guys.
Thank you in advance for the advice.
