Cowl Hood Way to big
Nates84cutlass
19
2
Thomasboro, Illinois
So I have recently acquired a 78 Regal, This thing has a massive cowl hood. I believe it is 6 inches, The height doesn't bother me as much as the fact that you can open it about half way before it hits the windshield!
I was wondering if anyone has had experience with getting around that, aftermarket hinges or something. To be honest I haven't looked into it too deeply yet, I still have to trailer it home (No Motor).
Qdub24
1,796
785
Columbus, GA
I would think that it should be a pin-on, lift-off hood. Maybe you should make it into one.
3XBrownCutty
1,820
9
38
NW PA
Or you could "trim" the back of the scoop so it clears...
beermonkey9417
2,443
12
38
des plaines, il
i would think trimming it would effect the air flow. But what do i know, i never had a cowl hood. :cry:
Blake442
6,866
2,011
Minneapolis
X2
Trimming is the only way to get it to clear, unless you want to do away with the hinges all together and lift it off.
custom442
1,889
5
Houston
... 6 inch hood and youre wanting to use the stock mounting brackets? Get some cheap hood pins. There are also kits if you want to spend $$ to have the hood lift vertically or to the front
Nates84cutlass
19
2
Not to big on hood pins. I trimmed it, only had to take an inch and a half or so off.
Thanks
