Thanks Bonnewagon... Your explanation helps me immensely. I've been trying to solve an oil consumption issue and was suspecting it was due to over ventilation of my PCV system. I've been running a open element type breather filter on one valve cover and the PCV valve to the base of the carb on the other. This seems to be providing too much flow and is allowing oil to be consumed through the intake during highway speeds at higher sustained RPM's. I'm going to try using a closed breather filter with a connection to the air filter and see if that helps balance things out a little better.
