That's too bad, make sure you break that cam in properly or it will be out again shortly.I already have it and put it in yesterday
The a/c was drained before I started, must of had a leak. I pulled everything and painted it.Don’t open the A/C if it works you can hang it out of the way over the fender don’t add to your cost you don’t need to completely remove it from the car if it still works
Yes I know 30 minutes t 2,000-2,500 rpmThat's too bad, make sure you break that cam in properly or it will be out again shortly.
Thank & yes it’s a turn key , not sure if they set the preload I will have to check that out thanks for the heads up. I knew about the priming to and was going to get one.Welcome to the affliction. Sounds like accessories will not be a problem after all. Nice car to start from. Choose an oil with 'zinc' or 'ZDDP'. Recommend priming the engine before start, check the instruction sheet that I hope came with your motor. Unclear whether this is part of 'turn key'. Any hint whether they set the lifter preload? Best choice is to take off both valve covers and turn the motor over two complete turns once the drill motor 'slows down' meaning it is pushing oil. Priming tool will also be handy when inserting the distributor. If you can spin the pushrods in your fingers after priming, they did not set preload. I could go on, but I'll wait for your request before triggering the second barrel...
Thanks good to know, what headers and exhaust did you go with?I bought that exact motor for my Malibu wagon. Not a bad swap but it took a little bit of work. You'll need a Cutlass condensor for the AC since the lines are on the right side. I havent bought the AC lines from the compressor but Ive been told I'll need lines from an F body. Wiring took a little time but mostly because Im fussy. You'll need the right adaptor for the alternator too. Depends on what you have in the dash. Idiot light or gauge.
Some things are stupid. The wire loom brackets included with the motor are for aluminum heads. They wont work with the cast heads. Dipstick has to be put in while you put the right header on. Put it on ahead of time and the header wont go over it with the AC box on the firewall. Not a bit deal just something else I realized after the fact and had to redo.
Also since its got a vortec manifold I had to modify the kickdown bracket for the transmission since I have a TH350. You might also need a Holley high idle solenoid and the bracket for it. The bracket need to be cut and modified to fit the carb and manifold. No matter what it says in the description its not true. You have to hog it out to fit the carb linkage.
I used Hedman shortys. No exhaust system yet. Theres more pictures in my build thread.Thanks good to know, what headers and exhaust did you go with?
Looks goodI used Hedman shortys. No exhaust system yet. Theres more pictures in my build thread.
Thread starter | Title | Forum | Replies | Date |
G | Crate engine recommendation | General Discussion | 20 | |
S | Old 454 Crate Motor Specs Question | Engine / Swaps / Driveability | 19 | |
BBC 454 LS6 crate motor | Engine / Swaps / Driveability | 6 | |
J | Crate engine | Engine / Swaps / Driveability | 2 |
