No I got it with I just haven’t installed it yet.So you bought it without the serpentine setup ?
You could have put it all on ahead of time. MUCH easier. Especially the lower bolts. I had everything including the fan installed before I dropped it in. Another thing, is your steering box o ring or flare fittings ? I had to have both lines made by a local hose shop. When I redid the suspension I bought a Monte SS box with o ring fittings to match the new steering pump. Still had to have lines made.
Well I’m a rookie at this I figured it would be easier to get the headers in without the accessories in the way. I just cleaned up the stock steering box and am using it , I believe it had o rings. I did upgrade the steering shaft to the Jeep.
I knew I was going to have something’s to change and figure out so thanks you are being extremely helpful.
Thread starter | Title | Forum | Replies | Date |
G | Crate engine recommendation | General Discussion | 20 | |
S | Old 454 Crate Motor Specs Question | Engine / Swaps / Driveability | 19 | |
BBC 454 LS6 crate motor | Engine / Swaps / Driveability | 6 | |
J | Crate engine | Engine / Swaps / Driveability | 2 |
